John deere Trailfire 121
Got to test out my 121 trailfire today.
- Danzig
- Real Name: Paul File
Re: John deere Trailfire 121
and .....?
Works out very well. There is absolutely no ski lift, didn't feel any darting at high speeds.
Next up is a 136 liquifire.
First I pressed ski doo 2.52 drivers on the Deere driveshaft, and then I used the Deere suspension shafts where it mounts to the tunnel in the Polaris suspension because the deere tunnel is slight wider. It all bolted up after that.
smitfire wrote:First I pressed ski doo 2.52 drivers on the Deere driveshaft, and then I used the Deere suspension shafts where it mounts to the tunnel in the Polaris suspension because the deere tunnel is slight wider. It all bolted up after that.
excellent! You have any clearance up front at the drive?
1980 Liquifre 440 survivor
Yeah just enough, can't use any bigger lug than what I did without a drop and roll.
What Polaris is the track and suspension out of? You used a 3/4 lug track? I might actually do this... I hate my stock track... it just spins everywhere with no traction
It's just a Polaris 121 track, roughly .75 lug. I don't know what it came out of as I got it off a pile of parts at a salvage yard.
Needs to be a early 90's suspension before the Extra 10.
I'm hoping to do a 136 liquifire soon.
Looks like an Indy 500 suspension. You actually fit the JD mounts to it?
motoXman wrote:Looks like an Indy 500 suspension. You actually fit the JD mounts to it?
Bolted right up, didn't have to change any holes on the tunnel.
Excellent. Indy's go cheap around here. Might look for one, use the suspension for the LF and the motor for a go cart
- jdsledsrgr8
- Real Name: Matt Gabler
Indy suspension fits just fine. Think about a reenforcement plate around the bolt holes on the inside of the tunnel to be safe; alot of pressure on the bolts through pretty thin metal.
Mt. Horeb WI
1976 Liquidator
1976 Liquidator Clone
1978 Liquifire 440
1976 Liquidator
1978 Liquifire 440
- Real Name: Lloyd
I have all the parts except the drive sprokects gathered up to put a 121 " track and Polaris suspension out of a 93 Indy 500 in one of my Liquifire's
Did you really use the original mounting holes?
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
