Black hard plastic restoration
GreenGenes
Real Name: Terry
Post by GreenGenes »
Has anyone found a good product to use that restores the black hard cowling plastic ?.
Just looking for a quick spray product, not looking to repaint.
WD-40 is not the answer I'm looking for.
Hope someone has found something good. :shifty:
1973 JDX-8
1974 JD300
1981 Liquifire
1981 Jag F/A 340
Re: Black hard plastic restoration
You'll probably get several replys all of which will be good. Personally I use Bondo's "RestoreBlack" from Walmart.
DA...you ever had issues with the restore black flaking off a year or two later?
I used it on a tank. Scrubbed with soapy water, wiped with paint thinner before applying about 5 coats of restore black. Thank looked excellent until it started flaking off.
Sent from my Motorola RAZR MAXX using Tapatalk
Uh...no I don't think so. Perhaps an early resto when gas spilled over the tank but I'm thinking we just went back over it.
Krylon Fussion Satin Black get my vote.
No surface prep need.
Danzig
Real Name: Paul File
Post by Danzig »
Paint thinner, xylene, mr. Clean magic erasers
Brake Fluid
Grumpy
eppjd
Post by eppjd »
JDT wrote:Krylon Fussion Satin Black get my vote.
I agree, except I prep more. Scotch brite to remove oxidation, then clean with soap/water and then alcohol to clean the surface
Adam Epp
Winnipeg, MB, Canada
74 400 (2 - sold)
Well yes, soap and water with a stiff bristle nylon brush.
Rinse, dry and paint. Works fantastic.
GreenGenes
Real Name: Terry
Thanks everyone for the replies... I will have some time this weekend to do some experimenting :clap:
1973 JDX-8
1974 JD300
1981 Liquifire
1981 Jag F/A 340
