Wanted: Brake handlebar block 75 JD 400
liquifireguy
Post by liquifireguy »
I am needing the brake handlebar block for my 75 400. The set screw is stripped out on mine. Please call 765-427-3441 or PM me if you have one
lwb140
Real Name: Wade bennett
Re: Wanted: Brake handlebar block 75 JD 400
Post by lwb140 »
hello , ive probably got a good one here , if you need one , if the block is ok otherwise I usually glue mine on because the old aluminum many times wont hold a set screw . im just south of Lafayette !! great to see another hoosier here !! wade
liquifireguy
Wade, I sent you a pm. Thanks, Jeff
