Wood seat frame
440 rat
Wood seat frame
Post by 440 rat »
Does anyone have pictures and measurements of the plywood for the 76 liquifire?
lwb140
Real Name: Wade bennett
Re: Wood seat frame
Post by lwb140 »
they just had strips down the sides
ljm
Real Name: Lloyd
Re: Wood seat frame
Post by ljm »
I just did a 77 Liquifire seat
2.5 by 34.5 I think were the measurements for each strip
Several Deere's
Several Kawasaki's
ACSCC #1534
JDMIKE8100
Re: Wood seat frame
Post by JDMIKE8100 »
Try to get the pattern off the old seat if you can.
If not,the wood is notched at the front to go under the hold downs by the fuel tank.
The wood is about 2'' wide,one bolt hole for each side at back of tunnel hold the seat.
Need the nut with the spur on it for the wood strip.
440 rat
Re: Wood seat frame
Post by 440 rat »
I don't have an old one to go by. Someone made a base out of plywood thats as wide as the seat foam so it sits on top of the heat exchangers instead of around them. If someone has pictures of one that would be awesome, I'd like to see how/what the seat cover attaches to on each end(over the tail light and gas tank).
Re: Wood seat frame
The wood strips lay inside the molded pockets on the sides. The wood was glued to the bottom of the foam and the seat covering was stretched over the wood on the sides and ends and stabled into place. The seat covering was glued to the bottom of the seat foam around the taillight and up front around the notches that are cut out for the seat clips. Measure the inside of the pockets in the bottom of the seat, cut the wood to fit and the lay the wood on the tunnel to figure out where to cut the notches in the front and drill the holes for the rear mount. The wood slides around the seat clip about 3/4 of an inch with the tab on top.
Here is a sketch of the what the wood strip should look like.
seat strip.png (4.69 KiB) Viewed 658 times
440 rat
Re: Wood seat frame
Post by 440 rat »
Thanks harleysportster
Re: Wood seat frame
Nice job there Pat.
