'78 LF or Cyclone Tunnel
Andrew27
Post by Andrew27 »
Trying to find the part I need which isn't likely I've been told so prob. looking for a tunnel for my '78 LF. Cyclone tunnel will work too right?
PArt I need is Deere part # AM54204. Its the alum braket that hold bottom of steering rod in place to the tunnel.
'78 440 Liquifire - (2)
'80 440 Liquifire
'81 440 Liquifire
Re: '78 LF or Cyclone Tunnel
The lower steering bracket AM54204 was original on the 77/78 Cyclone/Liquifires and a replacement on the 76 Cyclone / Liquifire. I do not have one but someone probably will, just give it a day or so.
smitfire
Real Name: Dustin Smit
Post by smitfire »
I'm parting out a 77 liquifire if its the same.
Andrew27
Post by Andrew27 »
Yes '77/'78 LF should be the same from what I know. I'll send a PM to see what we can come up with.
'80 440 Liquifire
'81 440 Liquifire
Check the bulkhead for cracks when you remove the bracket. They are known to crack.
