Drive Sproket Bolt
nothingbutadeere
Real Name: Todd Landry
Drive Sproket Bolt
Post by nothingbutadeere »
Does anyone know what size bolt is used to secure the drive sprocket to the drive shaft?
I must have lost one some time ago and the other one finally decided it had enough and wanted to leave too :doh: The holes are in good shape and don't show any signs of rounding out or abnormal wear.
Re: Drive Sproket Bolt
5/16"
M63678 was the cap screw that retained the drive sprocket on a lot of models.
I have some NOS ones here with the plastic dot in the threads, I believe they are the correct bolt.
They are 3/8" dia X 1 1/8" long.
nothingbutadeere
I was able to use a 5/16" x 3" cap screw and a locking nut, with washers of course.
Larrytkd
Post by Larrytkd »
I used the same ones that were in the axle plus a little blue threadlock.
