Hello!
Does anyone have mounted extra tunnel coolers on a Liquifire -81? Thought about the water pump function? Sincerely,
Stefan Hellgren Sweden
Tunnel radiator Liquifire
- fireburst rider
Re: Tunnel radiator Liquifire
I thought I saw someone had mounted copper lines under the tunnel as a cooling solution, but I dont believe the sled was a liquid cooled sled, just that they had put a liquid cooled engine in an air cooled sled which did not have provisions for a heat exchanger.
I removed the tunnel heat exchanger and put a polaris heat exchanger on the right hand running board. I have had no over heating issues.
