Replacing Mikuni needle & seat
ammon
Real Name: Layne
Post by ammon »
I bought some parts from Matt, and I am inside the mikuni carb on my 81 Sportfire. In the Deere parts catalog, it lists a M65377, "ARM". Holding this arm in place is a "PIN", M65338. I need this out of the way so I can replace the "Mikuni 1.5 needle & seat". So do I drive the pin out and replace the needle and seat then re-use this PIN to re-attatch the ARM? I don't want to go banging around until I consult you friends.
If I do remove this pin, what is the safest way without ruining things? :bonk:
ammon
5th- Still looking for
Re: Replacing Mikuni needle & seat
The pin is probably just a little stuck in there, give it a gentile tap with a center punch or something and it should come right out.
Also,try slipping a thin screw driver under the head of the pin and gently loosen it. There is scored portion under the head which holds it in place.
Sent from my XT1080 using Tapatalk
skoalmint
Post by skoalmint »
Turn the carb on its side and place a small 1/4 in deepwell socket under the cast portion of the carb directly under where the pin will be coming out, then take a small punch and gently tap on the pin. I have broke the casting supports off before :bonk: . Yours may not be stuck, but just a precaution. Brock
ammon
Real Name: Layne
Post by ammon »
I appreciate the suggestions. I will be going out this late morning to try this out. Thanks for your help
Ammon
ammon
Real Name: Layne
Post by ammon »
It's done. Thanks guys. :P
DeereKid9
Real Name: Bob Amber
Post by DeereKid9 »
Future reference: buy a spring loaded window punch. One pop every time.
Sent from my SPH-L710 using Tapatalk
I like that idea Bob. :dance:
DeereKid9 wrote:Future reference: buy a spring loaded window punch. One pop every time.
I had to Google that, for a second I thought it was like a left-handed smoke shifter or a muffler bearing.
Same as a spring loaded center punch I believe.
DeereKid9
Post by DeereKid9 »
Yes, unless you're a fireman, then you get to punch Windows. One perk of the job. :)
Bob got any good deals on used car stereos? GPS units?
Air bags?
DeereKid9
Post by DeereKid9 »
Still a good supply of "Nice" kraco cassette players available, jvc boom boxes, and some alpine speakers. What's your pleasure?
