carb-engine
carb-engine
hey Guys I finally got my 72 sled to produce good spark after hours, weeks, and months of work. But, now I seem to not to get the carb pump to work. I was checking the line from the carb to the engine, but I dont seem to be getting blow by or suction from the tube. I blew thru the tube and its clear. Any ideal what it might be that is causing the problem? The engine has great compression. Putting a wad of paper in the tube, it wouldn't blow it out, nor suck it in.
Re: carb-engine
Could be a bad crank seal. Here is an article about the fuel pump in relation to the crankcase:
http://www.jdsleds.com/community/viewto ... 31&t=16409
Re: carb-engine
hey Matt thanks a bunch! I guess, I need to break the crankcase apart and get the seals replaced. What a job thats going to be. Plus I'm going to convert to a Mukuni while I'm at it. May the force be with me young skywalker! lol Thanks
Randy
Randy
Re: carb-engine
For the KIORITZ motor, from my understanding, you shouldn't have to split the crank case to replace the seals.
75 jd 800 - original
80 jd trailfire 440
2-79 jd trailfire 340
71 ski-doo nordic 399e
80 jd liquifire 440
80 jd trailfire 440
80 jd liquifire 440
Re: carb-engine
Al is right, you can replace the outer seals on a CCW/Kiortz motor without splitting the cases. But if you want to replace the inner seals, you need to pull the crank.
I hope this helps,
I hope this helps,
Re: carb-engine
ok, I will look into not splitting the case.
