Liquifire arm needed
I'm looking for the rear arm for an 80 to 84 liquifire.
Inside Shaft must be loose!
PM me or feel free to call and text 712 441 0286.
Re: Liquifire arm needed
If you have one with a frozen shaft...
Heat it up red hot.... then quench it. Thread a socket screw (allen drive) into the shaft and use an air hammer to pound out the shaft.
Heat and quench a few times as needed. I just started using this method and have good luck!
(You can thank Kenny if it works for you too)
Eric A.
427cobra wrote:If you have one with a frozen shaft...
Oh yeah I have a pile of frozen up ones.
- Real Name: Bob Amber
Dustin,
To follow up, I did have one that was seized too. So, we're in the same boat. But I'll try this method now too.
Bob
Bob
Seems like the liquifires are always froze up, and the trailfires and sportfires are loose.
Maybe it's just me..
- Real Name: Chris Farrell
rust electrolysis. All you need is Water, Arm & hammer laundry detergent(non-scented powder type). a big plastic tub, mechanics wire or metal coat hanger for hanging part. and a battery charger, scrap peice of steel tubing or rod. dip you arms in this process and the shaft will just about fall out. may take 12-48 hours depending on the rust. I do this all the time with all rusty parts. works great.
https://www.youtube.com/watch?v=54ADeB6V1rQ
79 spitfire. 78 cyclone 440
76 liqufire 340. 80 liquifire
76 liquifire 440 x 2
Chris' response sounds like a whole lot more fun. Anytime you can mix water and electricity, THAT'S A FUN PROJECT!
Have you tried the muriatic acid method? It dissolves the aluminum shafts.
I do have a jug out there, any tips or time frame needed?Matt wrote:Have you tried the muriatic acid method? It dissolves the aluminum shafts.
Use it in a plastic bin. Handle with care outdoors and away from walls. When you put the shaft in the acid it will sizzle and smoke for a few hours before it looses it's potency. Then you check and see how much shaft it burned out. The first couple gallons I got were a "green" version, and didn't each much of the shaft. Then I tried a different brand and it did the job much faster. So if strictly using the good stuff I would guess it would only take a treatment or two. Note that it will eat the paint off the arm too and you should primer it quickly after you wash off the acid. This is the stuff that worked:
Straight acid or did you mix with water?
- jdrob
- Real Name: Rob
I have used the acid method and it works great. DO NOT BREATHE FUMES IN .... make sure bin is vented. It will eat all aluminum away plus any rust on the steel. Makes a rear swing arm look new. Also make sure you prime or paint it within an hr or 2 of it coming out of the acid.
Jdrob
