1979 JD Trailfire Parts For Sale
bbagwell
Real Name: Brian Bagwell
Post by bbagwell »
Edited: As it turns out, the guy that I bought these from had no idea what year they are. I just checked serial numbers, and the engine is out of a 1982 Trailfire, the body I'm parting out is a 79.
So I was running my Trailfire when the engine quit on me. After taking the cylinder heads off, I found that the PTO side cylinder was marred. I tried to hone it, but it seems like the gouge was too deep. Rather than put more money into, I've decided to part it out and try to recoup some money to keep my wife from lecturing me. It seems that the bottom half of the engine is fine, and the RH coil side cylinder is also fine. Track is in decent shape, and I have the track suspension, as well as an additional track suspension that came with the machine. The PTO and clutch are good. The carb works, but probably needs some carb cleaner run through it. If you'd like to see any pictures of specific parts, just text or pm me. Phone number is 330-5four0-12six0. Thanks!
