correct spark plug
correct spark plug
what are the correct plugs that are to be in my 76 cyclone 440? /22 motor I have two different plugs in it.. would like ngk plugs so if someone has a cross because I know stock are probably champions..
Rebuilding aluminum idler wheels for you! new bearings, solid rivets, and polishing. PM for details
Seeking 76 Cyclone 440 parts
Low black windshield
Complete seat or just the cover
Re: correct spark plug
We have always run NGK BR9ES plugs in our Kioritz reed engines and had great luck. That should be the one you need.
DE
DE
Dustin Elder
Salem, OH
Salem, OH
thank you
Technically the 440 /22 fan engine should have B10ES plugs and the 440 liquid engine can run the '9's. You do not need to run the "R" type resistor plugs.
Sent from my XT1080 using Tapatalk
will the br9es hurt? I have easier access to them over the b10es plugs?
The 10 series is a colder style plug which will handle more heat. If you are just casually trail riding, the 9 should be fine. If you are running it hard, run the 10's. Don't forget to check your fan belt.
