Just an Idea
Just an Idea
Tossing around an idea of making a portable gas tank to start and tune without having to put gas in the sleds tank. Thinking about getting a 1 gallon gas can and putting a tank fitting in the side then add a shutoff and fuel line. I could then attach to carb and start engine. When done, just shutoff gas and remove line. Has anybody done anything similar, if so how did it work?
Re: Just an Idea
Yes. I think someone one the site has made something similar. Look in the tips and tricks section? I use a motion pro hanging bottle (it just hangs off the handle bars with a long hose and a shut off valve) that is very similar to what you describe and it works great also.
Re: Just an Idea
Yep, that will work fine. Have seen them used at dealer service shops, especially when priming a repaired oil injection system.
Re: Just an Idea
Yes I do this all the time. I use a 1 gal fuel container which fits nice on the floor board. Drop one end of the fuel line into the container (with a screen pick-up) the other end goes to the fuel pump. I usually stuff a shop towel around the line going into the tank to help keep things in place.
The container I use is actually for my weedwacker, snowblower, chainsaw, etc... They all use the same mix. So no need to use a special container for me.
This eliminates the need to fill up the fuel tank on the sled.
Eric A.
Re: Just an Idea
I didn't put a check valve style pickup inside the tank. I use the mityvac to put a little pressure on the tank to pre fill the carbs.......I hate pulling my guts out. I can also flip the mityvac to vacuum and suck the last bit of fuel out of the tank when summerizing the sleds
Re: Just an Idea
Yup just grab the weed eater can and stick the pick up line into the filler hole. Use a squeeze bulb to pump the gas to the carb.427cobra wrote:Yes I do this all the time. I use a 1 gal fuel container which fits nice on the floor board. Drop one end of the fuel line into the container (with a screen pick-up) the other end goes to the fuel pump. I usually stuff a shop towel around the line going into the tank to help keep things in place.
Sometimes I just use a 16 oz pop bottle. Hole in the cap to push the fuel line into.
Re: Just an Idea
We just use a gallon plastic container and stick the fuel line in. Nothing magical and it saves from putting gas in the tank until you're ready.
