Hello i have bought a trailfire 340 and was checking the chaincase and found out the chain is bad.
Checking the sprocket and noticed they are not standard.
17 tooth and 35 tooth And the numbers is 0107-218 - 0107-325 Artic cat sprockets.
Ill guess artic cat sprockets fits on john deere. ?
Trailfire sprockets
Re: Trailfire sprockets
Correct,the early Arctic Cats gears are the same. The gear ratio is 2.06:1 with 17 and 35 Tooth Gears and 62 Pitch Chain.
