Well I joined the board about 9 years ago IIRC... had a 75 JDX8 that I'd found abandoned. Got it running and cleaned up then promptly sold it as I was a broke kid that needed the cash way worse than a vintage sled. Now 9 years later I wish I still had it so I set out to find one. Came across a fairly complete 1973 and picked it up this weekend. Has electric start that works but I need to fix the battery box as the solenoid is in the path of the steering linkage with the weight of the battery in the box. It has what I believe is a Walbro WF carburetor... had a bad hesitation between idle and WOT but opening the low side screw seems to have eliminated that. Screw is about 2 1/8 turns out which seems excessive but it seems to run decently. Lots of other little things that it needs, many of which I'm sure I havent even noticed yet but it will be a fun project to get it all in running order again and may even turn into a full resto down the road. Look forward to being a part of this community, there is a wealth of knowledge here!
New old member with 73 JDX8 questions
1973 JDX8 - Current project
1975 JDX8 - Gone but not forgotten
Re: New old member with 73 JDX8 questions
Where in Montana are you? I'm in Red Lodge.
I'm off in the crappy eastern part of the state. May as well be North DakotaFairchild wrote:Where in Montana are you? I'm in Red Lodge.
