Mikuni on JD 300
modmod1
Real Name: mario medeiros
Mikuni on JD 300
Post by modmod1 »
I just got a 300 motor and it came with a Mikuni carb and wanted to ask if this carb will work.
It has 8H9 01 on the side and measures 38 mm and is a butterfly carb.
Any idea on what jet sizes I should use or what the air idle screw should be set at?
SS440-80
Real Name: Robert
Re: Mikuni on JD 300
Post by SS440-80 »
The Yamaha Enticer 300 used Mikuni 8H9.
The jetting for the ET300 was:
Main jet #210
Pilot jet #90
Air/fuel screw 1-1/4 to 1-1/2 turn out.
That would give you a good start when jetting for your 300.
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
modmod1
Post by modmod1 »
Awesome thank you
modmod1
Post by modmod1 »
Sorry 1 last question any idea of the float height? Thanks
SS440-80
Real Name: Robert
Post by SS440-80 »
If you look at this link, in chapter 3 you find all info for your carb that you need :dance:
http://www.vintagesnow.com/Yamaha_files ... 00g_SM.pdf
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
modmod1
Post by modmod1 »
Again thank you much.
SS440-80
Real Name: Robert
Post by SS440-80 »
Let us know what jetting you end up with. It could be a good help for someone else sometime...
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
modmod1
Post by modmod1 »
No problem
