Bearings and seals
jdjock
Real Name: Tom Schuster
Bearings and seals
Post by jdjock »
Where should I look for fan bearings for my 340/S and crank seal for my sportfire. Matt doesn’t show the brgs in the store and he is out of the common crank seal. Thanks for any info. Tom
Re: Bearings and seals
Since I am out of those seals and so is Don (both our suppliers are wiped out) Dennis Kirk says they have a few: https://www.denniskirk.com/winderosa/cr ... d/1473.sku
The fan bearings are common metric bearings. You have 2 choices: Take the bearings or the dimensions to a bearing supply house and have them match them up. I suspect my Case/IH dealer could get them, but as they sell Yamaha, they might go through Parts Unlimited as well.
Or, contact Rainville, last I knew he had NOS.
As for the seals; looks like Manufacturers Supply has them. https://www.mfgsupply.com/garage/vehicl ... 40%252f22/
jdjock
Post by jdjock »
Thanks Matt. I ordered a couple from DK. Looks like he has 2 left in stock. I’ll check around Sioux Falls this week for the metric bearings. Thanks again all. Tom
jdjock
Post by jdjock »
Brian, the case/IH dealer in Sioux Falls had the bearings in stock. Thanks for the tip. Tom
