Ok, what do all of you think the best spark plug would be for a JDX4 and a 600 that has a KEC 340/5 in it?
I'll tell you what I pulled out of them, it doesn't seem correct that is why I'm asking....
JDX4 had NGK B8ES
the 600 with the 340/5 had Champion RN-3 (which the parts dealers couldn't find)
I was think of putting in the B8ES in the JDX4
and NGK BR9ES in the 600.
any thoughts?
Oh yea, what torque should they be?
Gary (GRP)
Spark Plugs....
Spark Plugs....
Gary,
From what I figured out, the normal spark plug would be Champion N2 or NGK B9ES. The R in either plug means resistor and unless you are using a wireless headset you don't need it. Just watch the color of the plug after a run at WOT and then shut down the engine. It should be card-board color. The newer champion plugs such as RN2C is availalble, the C means the electrode is made of copper.
Spark Plugs....
not a bright parts dealer then.. n2c rn2c or n3c rn3c. there is always an ongoing disagreement on which is better champion or ngk.. try both and use the ones you like.
Spark Plugs....
I have so much to learn, I just wish I had some snow to run these to see what works best. Being so new into this is a real disadvantage. I've got years of work with all of the sleds I have so I will be learning as time goes on.....
I just feel lucky to find what I have so far and I can only do one at a time.
I know I'll be bugging you Jacilynn to the point that you might even get sick of me!
Hope not.....
Gary (GRP)
Hope not.....
Gary (GRP)
