Last year I went ahead and bought a hewtech cdi and a nos stator from dk trader . Everything was installed last spring and the sled ran great . Last weekend I fired up the sled and she ran great for about 15 minutes , but then sputtered and died . After a little trouble shooting I found that the stator is now reading 1.4 ohms rather that the 2.7 ohm which is required . Is there something that can make these go bad ? I have rechecked my wiring and connections and found nothing . Now I need to get another stator , but don't want to have the same thing happen.
Also does anyone have a good stator for sale ?
thanks in advance Kevin...
stator troubles
- flames4555
stator troubles
Kevin
76 cyclone 440 (dual carbs)
69 Arctic cat panther p22j
1982 kawasaki indtruder
1980 kawasaki 4/6
74 cheetah 440
1967 buick wildcat convertible
1980 kawasaki 4/6
74 cheetah 440
stator troubles
Flame,
Sorry to here about the stator. Rich(TakeitToTheLimit)had pointed out that the early stators with the square plugs did have problems even out of the box. I suggest getting a later style with the round plug and splicing it to the original wiring or installing all the components with the round plug. I found a stator for you, check you mail.
Harley
Harley
- flames4555
stator troubles
Thanks harley,
Thanks for the info on the Stator I'm gonna get it ordered this evening but it looks like the old style box connector version . Do you which sleds had the newer round plug version ?
thanks again
Kevin
thanks again
Kevin
Kevin
1980 kawasaki 4/6
74 cheetah 440
1980 kawasaki 4/6
74 cheetah 440
stator troubles
Kevin,
The plug connector was switched to the round style in 1978. PART#AM54174 is for 70001-80,000 cyclones but should work on yours. You will problably have to remove the old wires from the connector and install the wires of the new stator.
