Rebuilding Clutches - Part #'s?
I need to rebuild the clutches in my 76 Cyclone 440. Could someone tell me what Part #'s are for the cam sliders, springs, and whatever else i need to rebuild the clutches. Thanks. If you can, email me at xlh1000@comcast.net
The clutch is a comet 102-C clutch. Any of the major vendors sells the parts. Rebuilding depends on what is wrong with it. Common wear items are the cam roller pins and weights, spider guide Buttons , face plate bushings .
Thanks for the info. The sled itself is pretty beat, so I'll take the whole clutch apart and inspect the parts for wear to see what needs to be replaced.
