I recently replaced the chain case oil with a synthetic 75W-90W gear lube. Will this be ok...or do I need to run something a little thinner? All it said in the manual was to use the polaris chain case oil.
Eric
95 Indy XLT Polaris
95 Indy XLT Polaris
Eric A.
jddecalguy
95 Indy XLT Polaris
i would change it, that seems to be to thick. polaris chain case oil isn't that expensive and is about the same thickness as dexton. i know amsoil also makes a chain case lube that works.
jddecalguy
jddecalguy
95 Indy XLT Polaris
Alright...I'll have to change it when I get it out in the fall. I kind of figured it was a little thick.
Thanks!
Thanks!
Eric A.
95 Indy XLT Polaris
Ya my dad uses the Amsoil. I used some 80W-125 I think of my neighbors it was for his Deers transfer case or something. BOB
Liquifire 4/6
95 Indy XLT Polaris
Polaris does sell both a synthetic and a non synthetic chaincase lube....at least I think they still make the non synthetic. Personally, I'd go with the non synthetic if it's available because the synthetic stuff will leak past the tiniest imperfection in a seal, gasket, or o-ring.
Pete
Pete
Peter from Roblin, Manitoba
