Just wondering if I need to use this long skinny plate (runs the length of the carbide) when I put ski skins on the sled. What is its purpose?
I bought a pair of Polaris ski skins and it doesnt say anything in the installation instructions about using this "spacer" with the skins.
Eric
Polaris Questions
Polaris Questions
Eric A.
Polaris Questions
Oh ok.
So if a spacer is needed it will be included with the carbides?
I bought some new carbides so I will see what the installation instructions say.
Eric A.
Polaris Questions
Eric, I'm not really clear on which Polaris sled you have or what exactly it is that you describe as a spacer. However, I'm guessing that you bought a set of EZ-Steer Polaris wear rods. I attached a pic showing an EZ-Steer carbide with it's backer plate in the lower part of the pic and a standard Polaris full length rod at the top of the pic. If you have the EZ-Steer rods, you must use the backer plate (which I think might be the thing you describe as a spacer). It goes immediately above the wear rod and under the ski (or ski skin). Depending on which EZ-Steer kit you got, the studs may or may not be long enough to go through a thick ski skin. The idea of the EZ-Steer rods is to give a lighter feel to the steering and also to reduce darting. But personally, I don't care for them and prefer to use a moderately aggresive full length carbide without the backer plate.
Pete
Pete
Peter from Roblin, Manitoba
Polaris Questions
Well I have a 95 Indy XLT touring.
I took the old ski skins off along with the carbides (which were the full length ones). But they used the backer plate with the full length carbides. So I am not sure what the previous owner was thinking??
The new carbides I bought are the regular full length kind. So I will install the new ski skins along with the new carbides, with NO backer plate.
Thanks!
Thanks!
Eric A.
