Kioritz 340
tmartin
Kioritz 340
Post by tmartin »
I finally got my 1973 John Deere 400 running. After fighting with the engine in the sled for a week or so I finally decided to pull the engine. After removing the cylinders I found that the rings were stuck in the pistons. This explains why it would just pop into the intake. Of course as I tried to loosen the rings, I broke one. After an extensive search i finally located genuine ccw rings locally. I honed the cylinders, resealed the bottom end, and put new gaskets in it all the way around. I put the engine in yesterday and it fired up in about ten pulls. I tuned the carb for a half hour and got it running pretty darn good. Now I just need a clutch (the old salisbury has seen its better days), a ski, and a seat cover and she'll be ready for the wisconsin winter. Thanks for all the posts I received, they were very helpful.
1988 & 1991 Polaris Indy 650s
tmartin
Kioritz 340
Post by tmartin »
Do you have new springs to fix the salsbury 780 clutch??? There is three broke out of the six that are in there. What is your price????
Kioritz 340
Isn't the Salsbury 780 the newer version Salsbury with only one spring Like the Comets or am I wrong on the number???
If on your clutch 3 or the six clutch springs are broke , The rollers are probably also shot, along with the nylon slides, If Rich has a complete rebuild kit that's the way to go...
Kioritz 340
Rich, Which Salsbury was the newer style with a single spring, a cast cover, with like cooling fins built into the cover, Chaparral used these in 73 as a update kit after the flat side belt/clutch thingy didn't work out & these were a disaster also. I think Deere's part number for these clutches would be AM52323 or at least they were similar to this Deere clutch using this type of arm & roller setup....
Did Deere have good luck with these clutches??
Kioritz 340
Rich, OK thanks, I couldn't remember the number of that clutch..
