liquifier cooling
jdjason
liquifier cooling
Post by jdjason »
looking for a gauge, and thermostat. 77 liquifier 440 or another option thermostat temp says its 60 cel or 140 f will something else work ?
jd400 1973 running
jd800 1975 running
liquifier 440 1977 runn
sprintfire 340 1983 running
nitro 440 1973 rupp ????????
77 cyclone 440 basket case
working on resto 75 x8
jdjason
liquifier cooling
Post by jdjason »
looked into electric sender and gauge with idiot light .
only the problem is gauges are set at to high number and 140degrees would hardly register .
how hot can you run it safely?
jd400 1973 running
jd800 1975 running
