JD 340 rs/2
JD 340 rs/2
I may have found one of these anyone tell me more about it?
JD 340 rs/2
Should be marked on the fan housing, With a metal tag, fan cooled, piston ported, CDI ignition, twin carbs, Y pipe exhaust.
- HoosierDeereMan
- Real Name: Troy Miley
JD 340 rs/2
The serial number is stamped in the lower case half along with tag on the fan shroud. Make sure these numbers match as some may have swapped the fan tower at one time or another. Also you may want to pull the cluth and inspect the nose of the crank. If you find the nose is red it was a dyno tested ETD engine. Here are a few pictures of mine.
JD 340 rs/2
Are they rare at all ? The guy who has it says its a very rare slde.
- HoosierDeereMan
JD 340 rs/2
They sure aren't common. If you can get it better snag it. They were used in the '75 340/S race sled.
JD 340 rs/2
If you can send us some pics & we'll verify, also the 295/S motor will almost look Identical
JD 340 rs/2
Hard to imagine any "prototype" RS/2's made it to Maine though. Most would be in an area around Horicon don't you think? DA
JD 340 rs/2
Did not see any pics in first post. Post some pics. ED
JD 340 rs/2
Im going to look funny how stuff travels through time
- flames4555
JD 340 rs/2
I also found a 340 rs/2 motor a couple of years back here in new england , now if I only could find a chassis too....
Kevin
76 cyclone 440 (dual carbs)
69 Arctic cat panther p22j
1982 kawasaki indtruder
1980 kawasaki 4/6
74 cheetah 440
1967 buick wildcat convertible
1980 kawasaki 4/6
74 cheetah 440
JD 340 rs/2
Orrrrr........sell me the engine!!!!! DA
JD 340 rs/2
Don't listen to Don!
I'd be happy to take that bad boy off your hands.
JD 340 rs/2
Ah, Have tunnel only with alum pan, will sell,
