1980 liquifire
1980 liquifire
Hi my buddy just picked up a 1980 liquifire and there's alot of gummy stuff in the bottom of tank after dumping out the old gas. Is there anything we could use to clean out this tank.
1980 liquifire
Pinesol works good but it takes a couple of days. Just put enough in to cover the bottom of the tank,swish it aruond every once in a while and when you think it is clean rinse it out with hot water and let dry. Like I said it does take a couple of days but it does work,also works on carbs but it does tarnish the jets and other brass parts.
1980 liquifire
Doesn't that have a Kawasaki motor in it?
1980 liquifire
Yes it does
1980 liquifire
Great advice. I just took my tank offbig danno 1970 wrote:Pinesol works good but it takes a couple of days. Just put enough in to cover the bottom of the tank,swish it aruond every once in a while and when you think it is clean rinse it out with hot water and let dry. Like I said it does take a couple of days but it does work,also works on carbs but it does tarnish the jets and other brass parts.
:eek: , I couldn't believe the color of the gas I dumped out. The Pinesol turned into a nice milky substance, but it smells nice lol. I'm sure I'll be happy I did this even though it's was a pain. Now I need to fix the plywood in the seat.
76 El Tigre 5000 WRECKED
83 Trailfire LX sold wish I still had it
80 Liquifire running
80 Spitfire new project
