1979 Trailfire chaincase bearings
elachevr
Post by elachevr »
Hi,
I am having a tough time finding bearings locally for my trailfire. Would anyone know the size I should be looking for? Is it 25mm ID, 52 OD, and 15mm wide?
Eric
Nutter
Post by Nutter »
I replaced every bearing on my '80 TF except the ones on the crank and the upper idlers in the suspension (just bought new idlers instead) this Fall. They are all common bearings. You can get them all from Mfg Supply. Just measure and match them up.
