:eek: the nasty stuff that came out was unbelievable.
IN PROCESS: here is the tunnel/belly pan after painting with JD Blitz Black paint. I had to knock out a bunch of dents from the belly pan, since this machine apparently had hit every hidden boulder in the upper midwest...
The engine: had a stuck ring (too much carbon bulidup). otherwise it was fine. Didnt even need new rings. Honed the cylinders and put it back together. Shined up the exterior with a 3M scotchbrite wheel. Just over 2100 miles on the ODO, but the speedo key was twisted off (its fixed now), so who knows what the real mileage is.
and the finished product:
This JDX4 had the fabulous "options" of the handlebar pad and the little shock absorbers on the skis.
Everything works except the brake light (the little pin switch behind the brake lever is stuck for some reason).
On the hood is a little red Iowa registration sticker that says "EXPIRES 12-31-74" on it. I left that on there because I thought it was sorta neat.
I have about 500 bucks in it. Paint, seat cover, a couple NOS windsheilds, a LOT of new bolts, tunnel striping, and some other things I cant remember right now.
I'm using Honda HP2 synthetic premix at 44:1 and 89 octane pump gas. I'd like to add that Walbro carbs are some really WEIRD devices (I'm used to Keihins and Mikunis on MX bikes....).
Seems to lose its prime when it sits. Not sure why. It has new fuel lines, new filter, and a new little backflow-preventer doo-dad in the tank. Is it normal to have to squeeze the primer bulb a few times whenever you want to start it?
