JD 214 Lawnmower
wycrumb
JD 214 Lawnmower
Post by wycrumb »
Hi all,
I have been given a JD 214 Lawnmower from the 70's. I don't know anything about JD Lawn equipment so any info will be put to good use. I was given this mower by a family friend and he is also giving me a 210 that he is keeping the motor from. You may have seen my post about making it into a Snow-mower. Anyhow he told me the 214 runs but looses power after awhile and needs work done on the valves, he did it a few years ago and said that the 14hp engines commonly had this problem. I am wondering if anyone has a permanent fix for this, good temporary fix, or info on if the mower is worth getting from him. Like i said, there is also a 210 that may have parts other than the engine and it is all free so I am thinking it should be a good investment of my time and a small amount of my money.
Thanks for reading, looking forward to hearing what you have to say!
Wycrumb
'82 Kawasaki KZ650 CSR
'74 John Deere 300
'72 John Deere 400
'73 John Deere 400
'73 John Deere 600
'80 John Deere Sportfire 440
jdsnowfire
JD 214 Lawnmower
Post by jdsnowfire »
214 is a nice mower, had one for a while then upgraded to a 314. those engines seemed to have a tendancy to use oil though, eventuly had to replace the one on the 314- used a 12HP vanguard v-twin- much more power very few modifications- could probably be done on the 214 but may be harder as it is a comply different powertrain.
wycrumb
JD 214 Lawnmower
Post by wycrumb »
Thanks for replying, I have heard that the 14hp engines had problems b/c they had a dipper lubrication type system so when mowing ditched and such oil would not be delivered properly.
Wycrumb
'74 John Deere 300
'72 John Deere 400
'73 John Deere 400
'73 John Deere 600
