spitfire piston meltdown
andrew
Post by andrew »
went ice fishing fri.out about 4 miles from shore when it happened.got trailered in took the snowmobile to my shop and pulled the head.piston on the recoil side, same one i had rebuilt last year any body know what would cause this, fuel mixture is 50 to 1,I run with the air box on but not the hose, temp outside was 23 degrees.should be able to run 4 miles without a meltdown right....damn these free air deeres!!!!
jdsledwheelman
Post by jdsledwheelman »
If you get a vacuum leak on the intake manifold or a crank seal went bad. Or if the carburetor is dirty it will run lean and burn down. Keep that carb clean.
nick :wall:
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
77 440 cyclone spitfire
78 spitfire x2
79 spitfire
80 spitfire x3, liquifire x2, sportfire
81 spitfire
82 sprintfire, spitfire, 340 trailfire x2
83 snowfire
84 sprintfire, snowfire, trailfire lx
