Clip location
kansasen
Clip location
Post by kansasen »
Trying to figure out where the little tin holder that holds the the two oil lines going to the manifold witch bolt holds it on a 84 trail fire
kansasen
Re: Clip location
Post by kansasen »
Anyone?
Re: Clip location
I for one am not clear as to which part you want. Could I suggest that you go to www.vintagesnow.com and look at one of webman's manuals? Either that or you could look in the JD parts book available online.
kansasen
Re: Clip location
Post by kansasen »
looked in the jd service book that covers all the models never counld find the pic of it the two small oil lines that run fron the oil pump to the motor there a small holder i think goes on the lower maifold bolt to the right of the carb
ChickenRat
Re: Clip location
Post by ChickenRat »
I can check my '84 Trailfire LX and see if I see anything.
Robb
ChickenRat
Re: Clip location
I just took a look. Don't know exactly what you are talking about. Please describe the "Clip" Is it round? Square? Plastic? I'm not seeing what you describe so give me more detail.
Robb
