What is the difference of these two engine numbers?
TA440A-F202
TA440A-D202
Scott.
Motor Number TA440A-F202???
Re: Motor Number TA440A-F202???
If no one answers here, that might be a good question for the guys at kawasakitrax.com. They used a variety of engine versions over the years. The Deere versions didn't change much.
- guitardude081
- Real Name: Jack Durand
The '79 Trailfire motor was different than the rest. The difference in the 2 is probably '79 and '80-'84. Don't quote me on that, but I'm thinking that's the case. The newer motor had a couple of extra ponies.
~Jack
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
Those are both Deere motors but different years but thats all i can tell you since i am not that familiar with the Deere applications
manitobatrailfires
I've been away from jdsleds since the snow melted, but bought another Trailfire this morning so I had to log in and get a JD fix.
TA440A are 440 Trailfire engines, as I'm sure you're aware.
The fourth-to-last digit is the year code. D is a 1980, F is a 1982.
Very little change to the TA blocks throughout their run, but the F202 is the exception.
There was a piston ring change between 1979 and 1980, although the pistons are the same size and any matched piston/ring set should fit any cylinder.
The heads, case, and crank are the same through all model years.
The F202 had unique cylinders and head gasket. Same pistons, same case, same heads, though.
It would be interesting if someone knew what the difference actually was. Have you taken these engines apart? can you see any difference?
Eric
Eric
