cdi trigger assembly
so have there ever been issues with the trigger assemblies , anyone know the checvkout procedures on them ,where does the black wire go ? ground ? wade
Re: cdi trigger assembly
The triggers don't seem to have a high failure rate.
Ohm test:
Connect the red to the white, should read between 100 - 300 ohms.
Connect the white to black, 100 - 300 ohms.
Check each of the wires in turn to ground, meter should read open.
Ohm test:
The specs Brian stated are for the earlier 295/S , 340/S Style A ignition. Here are the specs for the B style.
http://www.hewtechelectronics.com/image ... WIRING.pdf
awesome , wade
