Spitfire Drive Bearing Question
scorp11
Post by scorp11 »
Took apart the spitfire rear skid and pulled the drive shaft. The bearing on the secondary clutch side did not have a locking collar on it. Looking at the service manual, I can't really tell from the photo and found nothing saying whether it should.
It was not spun and near as I can tell it gets pinched between the secondary clutch and the step that is built into the drive shaft.
Question is, should there be a lock color on this ? If so, since there is a step in the drive shaft there, do I just use one use one from a different larger ID bearing ?
Also, does anyone know a BCA bearing number for each side for this ?
Thanks much,
Kevin
augie
Re: Spitfire Drive Bearing Question
Post by augie »
i just changed mine over the summer, no locking collars, i got bearings at the deere dealership jd8665 right side, jd8562 left side. augie.
