spitfire carb
knighthawk
spitfire carb
Post by knighthawk »
hi guys
ok this is what im having problems i have a i have a spitfire that has the mukin butterfly and i want to change it to a round slide now i know the round slide was a vm28 but how do i id a carb as a vm28
Re: spitfire carb
look on the back side ( the side that slides into the carb to engine boot side ) right under where the choke plunger screws into the carb it should be marked like 28/XX, you probably could go as big as the Spitfire / Kawi's had ( 30mm ) But it will be harder on gas than the 28mm would be??
