Hopefully an easy question. I took my mostly restored 1980 Spit (in which I am using a 1978 Rebuilt Kohler motor) out for its first ride.... it had a few very encouraging moments during which time I couldn't keep the skis on the ground
![Smile :)](./images/smilies/icon_smile.gif)
, but would frequently loose power and struggle to stay running. Upon closer examination, I do not beleive it it getting a constant supply of fuel. I put 2 galllons of 40:1 in the tank, but the gas doesn't seem to want to flow into the fuel line. I am thinking that maybe the pick line has fallen off? or the filter is clogged???
When it is idleing (trying to idle)... I can see mostly air with a few thin layers of gas occassionally being pulled into the carb.... so... I guess the question is... should that line be filled solidly with gas????
If this is my only fix, I think I'll be in real good shape. Will post a picture soon.
I know this belongs in classified... but if anyone has a belt gaurd, I'd be interested.
(sorry for run on post... what plugs are people using with this Kohler???)
Thanks everyone.
Dan
