sportfire rear shock
440SPORTFIRE
Post by 440SPORTFIRE »
Dennis Kirt sells a rear shock for a Liquifire, will this work on a 80 sportfire?
Mailman
Real Name: Sandy Otte
Post by Mailman »
I found one on Ebay a while back and it works fine it is a Kimpex 114-14, it'
s measurements are 8" x 11 1/2". The bushings are larger but if you take the steel inserts out of the old shock the will fit just perfect in the new shock bushings. It should have that no. in some of the parts catalogs also. Mailman
Mailman
Post by Mailman »
Sorry I forgot to mention that I have a 81 Sportfire that I put it on. Mailman
deererunner
Post by deererunner »
I use a Kimpex 04-245 on both liq and sportfire,woks fine Deererunner.......
440SPORTFIRE
Thank you for your help. Timothy
