440 23/lc
440 23/lc
I need a head gasket for my 440 motor and I was also wondering how hard it is to change out cylinders? and where to get them. I had a wrist pin clip break and the pin came sliding out enough to contact the cylinder wall and took a good chunk out of the side. Thanks
Re: 440 23/lc
could your cylinder be bored you can get 40 over slugs for it wade
Re: 440 23/lc
I dont think they are bored now. Are they press in cylenders? where to get them??
Re: 440 23/lc
You use to have a few choices when the parts were available. There used to be several oversize pistons available which required a bore-job for fitment. check out DennisKirk or any of the other major vendors. Years ago I had new sleeves installed and used standard pistons in my 76 Liquifire. You may find NOS gaskets on Ebay.podeere wrote:I need a head gasket for my 440 motor and I was also wondering how hard it is to change out cylinders? and where to get them. I had a wrist pin clip break and the pin came sliding out enough to contact the cylinder wall and took a good chunk out of the side. Thanks
You may also find a good used mono-jug and pistons on Ebay.
Re: 440 23/lc
I can get the cylinders that are in it now bored out?? and just get pistons to match the new bore like .40 over? I asked on here a while ago for a head gasket and I cant remember who had one on here for like $20. If anyone has one on here I would be interested in buying one. I cant find one on dennis kirk without buying the whole gasket kit.
Re: 440 23/lc
Yes, the cylinders are boreable. They need to be inspected by a machine shop to determine the correct oversize piston.
If the scoring is to deep, the 0.040 over pistons will not work, then a used jug is on order.
Here is a link to DennisKirk with the available pistons.
66mm=standard
66.25mm=0.010
66.5mm=0.020
67mm=0.040
http://www.denniskirk.com/jsp/tpl/cmn/p ... mmyId=9567
Here is a link for a NOS head gasket
http://cgi.ebay.com/ebaymotors/NOS-JOHN ... ccessories
66mm=standard
66.25mm=0.010
66.5mm=0.020
67mm=0.040
Re: 440 23/lc
Perfect thanks a lot.
Re: 440 23/lc
Can I use a 340 head on a 440 engine??
Re: 440 23/lc
No, it raises the compression to excessively.podeere wrote:Can I use a 340 head on a 440 engine??
