1980 Trailfire 440
phishoook
1980 Trailfire 440
Post by phishoook »
Last year my sled started bogging once warmed. I can keep it running at an idle, but with a load it want's to die. On jack stands, It revs up and down and run like a champ, putting it on the ground is when i have problems. I cleaned the carb, checked the fuel pump, and couldn't find an air leak.
So today I put it back in the shop for the first time since last year. I got it going on the third pull with a shot of starting fluid. it sounds a little rough, but it has some old fuel in it. I took a temp reading at the Y-Pipe. It was about 100 degrees cooler on the pto side. The fan side was warmer.
Last year someone mentioned it might be a bad stator or corrosion on the flywheel. Is there a way to check the stator? Like an ohm reader?
Any help would be appreciated!
phishoook
Re: 1980 Trailfire 440
Post by phishoook »
I guess I put this in the wrong section. Could it be moved down to the right section?
Sounds like it is hitting on only one cylinder.
phishoook
Post by phishoook »
its getting spark at both. When I pull the plug wire it will continue to run on one cyl.
