TrailFire 340 Fuel Lines
big-john
Post by big-john »
I recently aquired an old sled and was told it was last run in July but it doesn't start. I have spark but don't seem to be getting any fuel as the plugs are dry. The only fuel lines I see are a return line that has a metal filter and then a shut off valve and then leads to a rectangular box. There are two lines from the box. One goes to the engine and the other to the carb. All are dry.
Where is the fuel supply line? I don't see any other lines.
Thanks for any help you can provide.
lwb140
Real Name: Wade bennett
Re: TrailFire 340 Fuel Lines
Post by lwb140 »
how everything in walcott ?? the little box is your fuel pump the line that goes to the motor is the pulse line the operates the pump there should be arrows on the pump that shows in and out but out goes to the carb and in goes to the tank there wont be a return but the supply line goes into the tank about half way up with a hose on the inside of the tank with a pickup on it . all of these parts are very replaceable rebuildable one thing to check is make sure the needle and seat sre opening up in th carb if it is stuck shut fuel wont pump , hope this helps wade
