Had the 600 going today. Running great then all of a suddenit quit.
Fan belt broke and over heated the motor.
I'm sure that the mag side piston is cooked.
Where can I get a piston for a KEC-440/5?
Anyone know what fan belt this motor takes?
I see you can get gasket sets from Winderosa. Has anyone used them? Or where else can I gaet gaskets?
thanks
Lloyd
Burned a piston on my 600 today
- Real Name: Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
- Real Name: Lloyd
Re: Burned a piston on my 600 today
Just found out ..... bore and stroke on a kawasaki 440 is the same as the KEC-440/5
Anyone ever tried the piston in a KEC-440/5
thanks
Lloyd
thanks
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Bore and stroke the same???
Even if this is true, the wrist pins may be different, skirts different, ring location pins different, ect.
A carefull eye balling side by side and some checking with a caliper would be in order.
