reed valve piston
JD600
reed valve piston
Post by JD600 »
Hi all.
I have a right side piston for a 340 reed valve engine. Do the 340/22 and the 340/23 use the same pistons? If not, is there any way i can tell?
DE
Dustin Elder
Salem, OH
Re: reed valve piston
Dustin,
The piston is the same for the 340/22 reed engine and the 340/23. There is an arrow on the top which would point to the exhaust port if positioned correctly.
