crankshaft for kioritz
rocknroll1970
Post by rocknroll1970 »
i have a 440 l/c kioritz motor the crank is frozed up im looking for a crank what i would like to know if there is anouther crank from anouther engine that i can use for it or not feedback would be helpful thanks :bonk:
Re: crankshaft for kioritz
Depending how bad it is, it may be salvageable. One of the web site sponsors here may be able to help you.
http://www.jdsleds.com/ads/crankshaft/c ... rvices.jpg
If you need to find another one, all 76 thru 78 Liquifire cranks(both 340 and 440) are interchangeable.
IF yours JUST needs main bearings & seals then it would be probably cheaper to fix yours then you know what you have.. IF you purchase a used crank there is a chance that it still might need rebuilding..
rocknroll1970
ICCSF 108 wrote:IF yours JUST needs main bearings & seals then it would be probably cheaper to fix yours then you know what you have.. IF you purchase a used crank there is a chance that it still might need rebuilding..
thanks for the feedback does anyone know about how much it is to rebuild one i thought i would cost 3 to 4 hundred bucks i just pick up tthe motor for 20 bucks i should maybe pull crank and clean it up it could be were it has a lot of rust still.
Bearings, seals, and labor should run less than $300. The needle bearings in the lower rods are unavailable, so they need to be good.
rocknroll1970
thanks for the feedback i did get the crank to loosen up i have to get the flywheel off it has a lot of rust what can i do to ge the the rust clean up or can i. i might have to get it rebuild.
Where is the rust? If it's rusty inside the case, the simple answer is that the crank is junk.
