I was wondering what is the best way to go with replacing the crank seals. Should i buy a nos crankshaft? Or get them pressed/resealed? How much does it cost to do that? And one last question- how do i know if mine are bad?
Mark
Crank Seals question
Re: Crank Seals question
Mark, I think JDT said it best: "sat outside 15 years = bad crank seals". Of course you can always take a chance and burn down a piston. DA
Take the engine completely apart. No need for a NOS crank. If there is rust on the crank i would send it up to get checked.
- Sprailfire340
Crank seals are cheap - less than $10 for the pair. They slip over the ends of the crankshaft and seal the crank into the case. You must split the case to replace the seals on that Kawi. That is a good time to assess the bearings on the crankshaft. The outside bearings can be replaced by most people, but if the rods or inner bearings are bad you will need a good crankshaft rebuilder. I highly recommend Jerome Kretzman (Crankshaft Services). He is a sponsor here and does an excellent job at very reasonable rates.
There is no good reason not to replace the seals. They are very, very cheap compared to the alternative.
- jdrob
- Real Name: Rob
Mark make sure to read up on what to do.. this is VERY good reading !
http://www.jdsleds.com/community/viewto ... 31&t=11425
Jdrob
Mark, owning vintage sleds is NOT easy. But it is rewarding when you do the job right.
