Jd 400 missing parts?
Should a 1975 jd 400 have a primer and if so who has one?
1983 sprintfire (original everything but paint)
1975 jd 400 (will be restored)
Re: Jd 400 missing parts?
It was a dealer option/kit, but I've barely ever seen them installed.
I have lots of spark in 1 cylinder what would cause that
anyone
In the FAQs there is a topic called: Trouble shooting your sled. That is one place to start.
You will find other helpful topics there as well.
- Real Name: Lloyd
have you lost spark on one cylinder?
Did you have spark on both?
what have you done to the sled?
Lloyd
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
I boght it from a member JDcornflakes and it came woth lots of parts Nos and used and I only filed the points through the flywheel ports
- Real Name: Lloyd
I have seen the sled. I have both bought from and sold to JDcornflakes. The NOS hood you got with the sled Dave got from me.
Was there spark on both cylinders?
check and recheck all the connections and grounds.
It would be a good idea to replace the crank seals in the motor.
Wish you were a little closer. It would be fun to help you with this project.
Lloyd
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
never was sprk on the cylinders so I filed both and only one made spark
- Real Name: Lloyd
Well your half way there.
At least when you have spark on one side you can switch parts to see what part the problem follows.
do you have a shop manual?
if you don't you can download one for free.
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
I am going to put some nos points because they look real bad (and they came in the deal)
- Real Name: Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
I have many!!!!!!!!!!!!!!!!
