Want photo of engine bay 1975 jd 400
I would like to see a photo of where the fuel pump goes on a 1975 jd400 (with a bendix carb).
1983 sprintfire (original everything but paint)
1975 jd 400 (will be restored)
Re: Want photo of engine bay 1975 jd 400
Personally I feel the best place for that setup is in the trash.
Parts are a BIG problem with the Bendix system.
Lots of good Walbro's out there or a Mikuni conversion is very straight forward and has been done by many of us.
I am restoring it is staying original.
In that case you are probably correct in keeping it as built.
There was a memeber that had some gasket kits remanufactured for the Bendix setup.
well at the moment I want to throw it out and put in my jdx4 motor I went form 1 cylinder spark to new points in the other to no spark
