Ignition timing
Cyclone440
Ignition timing
Post by Cyclone440 »
I have a question on the ignition timing for a CCW 440/21 engine. My Deere service manual says the timing for the 21, with Denso ignition, should be .023 BTDC, but the 440/22 is listed at .009 BTDC. What is the big diffence between these two engines for the timing change? Is the .023 correct?
Thank you
JDFanPa
Ignition timing
Post by JDFanPa »
these 2 motors have different pistons so I suspect the porting or port timing is the difference I would go by what is listed for your model
JDXsand00s
Ignition timing
Post by JDXsand00s »
I would say it is due to porting because I'm pretty sure that 21's and 22's have the same bore and stroke, just a different wrist pin size. A 21 is also 3 ported while the 22 is 5 ported. Thanks for the .009 info as well; I don't have the manual so I've timed both of my 22's to .023.
Cyclone440
Ignition timing
Thanks for the information guys. Ryan, if you ever need service manual specs, just let me know and I can email you a scanned picture.
Kevin
