Fan Belt Deflection
eddingsj
Fan Belt Deflection
Post by eddingsj »
Does anyone know if there is a specification for deflection on the fan belt. I put a new one on with the some shim configuration as the old one and it is super tight.
Jeff Eddings
South Weber, UT
1980 Trailfire 440
Re: Fan Belt Deflection
You will have to add one or more shims to get a deflection of 1/4-1/2".
Running the belt too tight will shorten belt and bearing life.
eddingsj
Post by eddingsj »
JDT wrote:You will have to add one or more shims to get a deflection of 1/4-1/2".
Thanks for the information, I will add the shims.
Jeff Eddings
South Weber, UT
1980 Trailfire 440
