$16 Temp Guage for the ole Liquifire
bverboy
Re: $16 Temp Guage for the ole Liquifire
Post by bverboy »
wish my jd 800 had a heat gauge. i wouldnt be where im at now.. :(
PolCat
Post by PolCat »
Dator76 wrote:The thermostat on 1st gen. liquifires opens at 165 F and 210 F is too hot. I would expect 2nd gen. to be similar. This I learned by running a dator without a tunnel cooler and with that cooler they would run 165. (dator & liquifire use same thermostat) I think my aftermarket guage came from autozone. It used the lower temp range compatable with a sled. The sled I put it in has been sold or i would post a pic.
I bought one of the digital ones that I posted. It starts at 104 red light comes on at 212 but keeps climbing, don't know the limit. I had it to 235.
Two things are needed to keep a LC sled in temp range.
Air flow through the radiator and snow on the cooler plate.
Running it on a stand in the shop will provide neither.
It will overheat.
A large fan in front of the sled and a garden hose running water over the cooler will do the trick for summer time testing.
Let me see if I understand this correctly............you took a perfectly good chrome trim ring and painted it black? What is this world coming to???? :bonk:
PolCat
Post by PolCat »
Here is the one I bought testing it on the bench. Red light comes on at 212 F. Checked it with the wife's cooking thermometer and it's right on.
Oooooohhhh I LIKE that!!
PolCat
Post by PolCat »
Forgot to add that I found an adapter from 16 mm to 1/8 pipe from JEGGS for the sending unit.
427cobra
Real Name: Eric
Post by 427cobra »
Yeah that digital gauge is pretty sharp!
I just installed a $16 gauge from autozone. Installation was straight forward and it works!
The JD service manual for Kawasaki powered Liquifires indicates an operating temp of 108 degrees F. Translating the needle in the window over the color coded decal on the factory setup to actual degrees will require some very scientific wild a**ed guessing.
PolCat
Post by PolCat »
I tried hooking up a rectifier for a 12 vdc power source and all the smoke got out.
427Cobra which one did you get at Autozone? I was just there and they only had dc powered gauges!
I think I'll buy another and just use a battery to power it.
427cobra
Real Name: Eric
Post by 427cobra »
Just a Sunpro mechanical gauge. I think there were two versions....the gauge faces were different. But they both started at 100deg.
