can anybody help me with the part number for the outer axle bearing for this sled would like to fix it before I sell it.
thanks,backyard bob
1974 jd 300 rear outer axle bearing number?
Re: 1974 jd 300 rear outer axle bearing number?
Its a common bearing, available from any bearing supply outlet. The original PN is no good. I just buy them by size.
The common number for the outer idler shaft bearings on the bogie sleds is 6205. The dimensions are 25mm ID X 52mm OD X 15mm W. I usually pick mine up at Tractor Supply. Hope this helps.
DE
DE
thanks to all that replied found some works great another jd back on the trails
